how to ssh on routers?
Answered Question
Apr 21st, 2008
How do I verify if a Cisco IOS version has IPSec(DES or 3DES) encryption software?
I want to enable ssh but each time I get the following error message
ban-top-dess(config)#crypto key generate rsa
The "^" is displayed below the "r" on crypto
% Invalid input detected at '^' marker.
Overall Rating: 4.5 (2 ratings)
banso_boy Mon, 04/21/2008 - 03:42
you mean if I don`t see "This product contains cryptographic features..." in the "show version" command then I cannot run ssh?
banso_boy Mon, 04/21/2008 - 03:58
by the way any idea on how I can enable ssh on the router? software upgrade? If yes how can I go about it? The router is cisco 2811.
Hope u can still offer some ideas here.
If you have the correct image - the configuration is very easy:-
ip domain-name blah.blah (this is required for the ssh key cert)
crypto key generate rsa general-keys modulus 1024 (module 1024 is optional, default key size is 512)
line vy 0 4 or 0 15
login
transport input ssh
You will need to upgrade the IOS image - for this you do need a valid CCO account that allows the download of IOS images.
I think there is a IOS image for the 2811 that has crypto - it's either IP Plus or Advanced security or something like, I am not sure 100% on that.
HTH.
banso_boy Mon, 04/21/2008 - 05:12
HTH,
yep, there is Advanced Security and Advanced IP services.
glen.grant Mon, 04/21/2008 - 06:05
  • Purple, 4500 points or more
Most crypto images will have a "K9" somewhere in the imagename.
