scheduling task
Apr 21st, 2008
Can we schedule a daily task to shut down and bring up the RF of the APs using WLC or WCS?
ericgarnel Mon, 04/21/2008 - 05:49
Not natively. You can script it to shut down the switch ports that the APs connect to via expect/tcl from a linux box and have cron run the script on a time schedule.
You could also use time-based ACLs on an upstream router/firewall, but that would not disable the radios, only disable access based on the ACLs.
