QOS & WMM
Apr 21st, 2008
I have a question about wireless WMM.... looking at a paper about it, the paper talked about 802.1p tagging... doesn't this assume that WMM is being used on a host that is trunking?
Also, i read that WMM & DSCP qos on the AP can't be enabled at the same time?
Thanks!
Lisa G
ericgarnel Mon, 04/21/2008 - 06:53
  • Gold, 750 points or more
Lisa, the dot1p tagging is on the dynamic interface of the controller. The wmm is on the client IF the client supports it
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1087878
snippet:
Configuring QoS Enhanced BSS (QBSS)
You can enable QBSS in these two modes:
•Wireless Multimedia (WMM) mode, which supports devices that meet the 802.11E QBSS standard
and also:
http://www.cisco.com/en/US/docs/wireless/controller/4.1/configuration/guide/c41wlan.html
The WLAN QoS level (platinum, gold, silver, or bronze) defines a specific 802.11e user priority (UP) for over-the-air traffic. This UP is used to derive the over-the-wire priorities for non-WMM traffic, and it also acts as the ceiling when managing WMM traffic with various levels of priorities. The access point uses this QoS-profile-specific UP in accordance with the values in Table 6-1 to derive the IP DSCP value that is visible on the wired LAN. see chart on the url too
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
