NATing the destination address
Apr 21st, 2008
I have configured NAT on the cisco router and wanted to do a address translation for the destination address. My local LAN is 192.168.1.0/24. My server is in a different network 192.168.2.2. from My 192.168.1.0/24 network, i would like to give dummy IP addres 192.168.3.4 and the router should NAT the same to orignal IP address (192.168.2.2) and route it to the destination. Request assistance in achieving the same.
Thank you
smahbub Fri, 04/25/2008 - 08:06
  • Silver, 250 points or more
NAT is of two types:a)Static and b)Dynamic. Since you want to use two private ip addresses internally you have to configure DYNAMIC NAT on your cisco router.Access lists are also to be configured as a part of NAT process.Following commands are to be given in order to configure the Dynamic NAT:
1. enable
2. configure terminal
3. ip nat pool name start-ip end-ip {netmask netmask | prefix-length prefix-length}
4. access-list access-list-number permit source [source-wildcard]
5. ip nat inside source list access-list-number pool name
6. interface type number
7. ip address ip-address mask
8. ip nat inside
9. exit
10. interface type number
11. ip address ip-address mask
12. ip nat outside
For examples of NAT configuration refer:
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6922_TSD_Products_Configuration_Guide_Chapter
