Bandwidth shaping/limiting on 7600 platform
Apr 21st, 2008
Is there an easy way to limit bandwith based on vlan og phys. interface on the 7600 or do you need to create policy maps and so on ?
All I want to do is to limit a vlan interface (og physical interface) to for example 0,5Mbit.
Rasmus Fauske
smahbub Fri, 04/25/2008 - 08:09
  • Silver, 250 points or more
Policing provides a means to limit the amount of bandwidth that traffic traveling through a given port, or a collection of ports in a VLAN.Policing allows the router to limit the rate of specific types to a level lower than what they might get otherwise based only the interface bandwidth.
For information on configuring qos policy to limit bandwidth refer:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/mplsqos.html#wp1481789
