ASA5510 failover setup
Apr 21st, 2008
hi there, im trying to setup failover between two ASA 5510 and on inter e0/3 (on both ASA's) i have plugged a crossover a cable directly connecting them. Will this work to configure LAN based failover with stateful failover or do I need to connect the 2 asa's with a serial cable?
solpandor Mon, 04/21/2008 - 08:41
andrew, thanks for the reply but having read that and looking at the diagram, it uses a serial cable and does not mention that straigh through ethernet cable can be used.
