Active Active Active Passive Config How many PublicIP Addresses do I need
Apr 21st, 2008
I am trying to decide whether to go with either Active Active or Active Passive configuration on my ASA 5510. I have the license to go with either but I my weak point is the public IP Addresses. So does anyone know, how many IP Addresses I will need
gbudd12345 Mon, 04/21/2008 - 12:16
Depends on how you set up the active/active firewalls and how you have the contexts set up. You do need at least one public address for the "outside" interface of each context. Then, if you are setting up static translations or NAT/PAT pools, you need that number for each context.
For active/passive (or active/active and only one context) you will only need 1 address for the interface....
