Hung calls in sh isdn active
penn
In my 3640 SIP-ISDN gateway, I am seeing calls in sh isdn active that I do not see in show isdn status:
aust-txl-3640-voip-1#sh isdn active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out 5127519502 5122934555 20 Unavail - 0
Out 5127941177 6045380034 304 Unavail - 0
Out 5124741554 5122411078 469 Unavail - 0
Out 5124180600 5122064764 122 Unavail - 0
Out 5124180600 8006311160 2280 Unavail - 0
Out 5127481225 5126083724 5405 Unavail - 0
Out 5124741554 5124047827 +43462 Unavail - 0
Out 5124512242 5124143057 +43663 Unavail - 0
Out 5124210800 5125904609 +58602 Unavail - 0
Out 5127941177 5128364988 +30217 Unavail - 0
Out 5128042299 5124784190 +58597 Unavail - 0
Out 5124741554 5123462086 +60290 Unavail - 0
Out 5129281600 8666573502 +37452 Unavail - 0
Out 5124180600 5126334404 +11627 Unavail - 0
Out 5123389293 5124235195 +48108 Unavail - 0
Out 5124512242 5128547001 2870 Unavail - 0
In 5127675224 5124818831 437 Unavail -
In 5129855966 5124741554 381 Unavail -
In 5123176372 5124512242 25 Unavail -
In 5123467743 5128042299 22 Unavail -
aust-txl-3640-voip-1#sh isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=310F, sapi=0, ces=0, B-chan=1, calltype=VOICE
Active dsl 0 CCBs = 1
The Free Channel Mask: 0x807FFFFE
Number of L2 Discards = 0, L2 Session ID = 2
ISDN Serial1/1:23 interface
dsl 1, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
5 Active Layer 3 Call(s)
CCB:callid=D764, sapi=0, ces=0, B-chan=22, calltype=VOICE
CCB:callid=D7C9, sapi=0, ces=0, B-chan=20, calltype=VOICE
CCB:callid=3102, sapi=0, ces=0, B-chan=1, calltype=VOICE
CCB:callid=D7CC, sapi=0, ces=0, B-chan=21, calltype=VOICE
CCB:callid=310E, sapi=0, ces=0, B-chan=2, calltype=VOICE
Active dsl 1 CCBs = 5
The Free Channel Mask: 0x8047FFFC
Number of L2 Discards = 0, L2 Session ID = 4
Total Allocated ISDN CCBs = 6
I have a 3640 SIP gateway:
System image file is "flash:c3640-js-mz.124-12.bin"
Cisco 3640 (R4700) processor (revision 0x00) with 98304K/32768K bytes of memory
sh run attached
5 Replies 5
paolo bevilacqua
Yes, sometime call reamins stuck and clear commands cannot do anything. Try latest maintenance for 12.4(12), if still the same it's matter for the TAC>
Is that the maintenance reachable through this page:
http://www.cisco.com/web/psa/products/tsd_products_support_maintain_and_operate.html
or somewhere else, could you advise?
Hi, you need a support contract to download software for the router.
So would you know what release fixes it?
I don't know, but you have no other choice than upgrade and hope. You can take debugs, but chances are they won't help if there is a bug in the isdn stack (happens often).
