ericgarnel Mon, 04/21/2008 - 09:31
You can do it from either. change the primary controller setting under the AP properties to point to the new controller and then save and reset the AP
marcellosozzo Mon, 04/21/2008 - 10:06
I have done as you suggested, specifing only as primary the desired WLC.
The LAP, which was configured by priming procedure, indeed still joints to same WLC, though its ip address was inserted in the controller list.
WLC software version is 5.0.148.0
best regards
marcello
Scott Fella Tue, 04/22/2008 - 04:01
Place the ap on the same subnet as the WLC you want it to join and set the WLC as the master. the ap will need an IP on the subnet and should be able to join this way. If this ap has a SSC, you will need to add that into the WLC.
ericgarnel Tue, 04/22/2008 - 07:39
Verify that the 1st WLC is not setup as a "master" controller too
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
