HSRP tracking via IP routing
Apr 21st, 2008
Hi all,
Is is possible to track HSRP by using routing the routing table. I found a link on Cisco's website:
//Start of Paste
track object-number interface interface-id ip routing
- Create a tracking list to track the IP routing state of an interface, and enter tracking configuration mode. IP-route tracking tracks an IP route in the routing table and the ability of an interface to route IP packets.
//End of paste
Could the tracking value decrement , if the routes for the next-hop interface were lost (because some error with connectivity or adjancies)?
Mike
lamav Mon, 04/21/2008 - 09:47
Hi:
Are you asking if it is possible to track an object's status and incorporate that into the HSRP environment?
The answer is yes, and the document that I believe you are citing discusses just that.
The point is to use object tracking to ensure that your traffic is not black-holed because of a lost interface/next-hop/route on the HSRP primary. You wouldn't want to forward traffic to a router that's lost its ability to forward the traffic to the next hop, right?
And yes, object tracking will leverage the HSRP group's priority settings to ensure that a router will not allow itself to continue being the HSRP primary if it has lost the tracked interface/route.
Victor
chintan-shah Wed, 09/03/2008 - 00:00
Hi Victor,
DOes 6500/su720 supports Object trackign feature for HSRP ?
I am running 12.2(18)SXF12a but doesn't find standby track CLI
Chintan
