presense on VMware for lab eval
Apr 21st, 2008
anybody managed to get presense ver 6.0 working on vmware ? i get right to end of install after connectivity checks pass and recieve fatal error. This is for lab enviroment not production !
Overall Rating: 5 (1 ratings)
Michael Owuor Mon, 04/21/2008 - 17:47
Should work. I have, with Maintenance Release 6.0(2), which has support for VMWare usage of Presence for a lab environment.
littledavewhite Tue, 04/22/2008 - 00:31
could you send me the config file for the vm or just the info on disk size and mem you have used, also what disk type ideo or scsi.
many thanks
matthewpage Tue, 04/22/2008 - 01:34
you can use a scsi harddrive. Make sure its 80gb or more. Set the ram to over 2GB. This can be turned down once you install. Every thing else is default.
Just to let you know. You must have CCM6.0 installed and running while your doing the install it will not work. CCM can be on vmware or hardware doesnt mater. Also Make sure you add the CUPS server as a application server in ccm before you start the install.
uddinabu1 Tue, 05/06/2008 - 19:35
Could you please provide the steps to install presence 6.x on Vmware?
what is the vmware version? I tried on DL320-G2 but it does not support presence 6.x even though it support UCM 6.x
Thanks in advance
