Cisco ASA5505 Clientless SSL VPN won't let me browse to the outside interfa
Answered Question
Apr 21st, 2008
I have a ASA 5505 that I would like to remote to and use its interface to browse the internet. I can almost get it working. In trouble shooting I have created a list of sites that show up in the SSL main page. One is AOL, sometimes when I click on the link, it will go to the website. I get a few messages about a certificate and an applet that runs. The name of the applet is When this runs the main site for AOL will load. If you click on anything else on that page it will not load. This is my first time setting up the Clientless SSL and I've tried about everything including starting from default settings.
I have the ASA 5505 attached to an inside interface on a CISCO 3640 that has its own Internet connections. The ASA also is attached to the Internet with own IP address. Im using a /30 address connecting the two.
Config is attached.
Correct Answer by smahbub about 8 years 6 months ago
Please check the configuration of clientless SSlVPN on the ASA 5505 by using the configuration guide present in the Url given below.This guide will help you to configure and check the configuration on the ASA 5505
Overall Rating: 3 (1 ratings)
