Phones Hung on Configuring IP
Apr 21st, 2008
Have a 2801 w/AdvIPServices and 7931 phones. This is my fifth such build out and the only difference that I can see is that I have changed to using ACS.
I have CME configured and can see all of the phones showing up in the configuration. I can ping the main IP Address of the VLAN these are on ( from the router.
I put the config from this and my most recent router into Hyperconf and have only two differences - IP Addresses and the config from ACS which is routing traffic through VLAN.
Is there a possibility that I have added something while working on AAA Authentication that has caused these addresses to be unreachable by the phones?
I did run a ping from my laptop on my VLAN 1 IP Address and am able to ping through the switch to
Any thoughts on this?
Jon Gauntt
Overall Rating: 3 (1 ratings)
justinfvoeller Thu, 04/24/2008 - 13:09
are your phones hooked to a switch, hub, ??
If they are hooked to a cisco switch, make sure that the "switchport voice vlan" is set.
JonGauntt Thu, 04/24/2008 - 13:12
It is a Cisco CE500. Actually, you were very close. The voice vlan was set on both sides. I identified the problem as being that my VLAN on the Switch was using VLAN 2 instead of the one I normally use. I misconfigured it. As soon as I took about 2 hours away from the problem I was able to think back on this rationally and think through the VLANs and found the mismatch.
Thanks for the response...
Jon Gauntt
