Bandwidth Assignment on PFC QOS
As I understand that we can NOT assign specific bandwidth to any P and Q queue with PFC QOS configuration, can I use “wrr-queue bandwidth” and “wrr-queue queue-limit” or any other way to achieve the requirement as following:
It is WS-6724 (1p3q8t) with policing up to 300M from the carrier and want to have 5M of COS 5 traffic and remained 50% for COS3/4, 20% for COS2 and 30% for the rest.
This 7606 doesn't have SIP so we can't use MQC QOS nor the policy maps.
irisrios Fri, 04/25/2008 - 11:39
Can you please provide a brief topology description specifying the direction of the traffic you want to apply the policing/queuing and in which interface(s) and direction you want to apply it?
To know about these commands you can use the following URL:
http://www.cisco.com/en/US/docs/routers/7600/ios/12.1E/command/reference/w1.html#wpxref43985
http://www.cisco.com/en/US/docs/routers/7600/ios/12.1E/command/reference/w1.html#wp1038823
Thanks for the reply.
Our 7606 Gi3/24 connects to PE router, the PE have policing to 300M for ingress traffic and limited the EF (COS 5) traffic to 5M.
I am trying to setup egress queue on my Gi3/24 facing PE for the requirement as following:
Seems "wrr-queue queue-limit" only for WRR, how to assign bandwidth for priority queue?
torontoyuxiang Tue, 06/17/2008 - 08:03
you can specify the wrr-queue queue size (Q1 to Q3) by using the 'wrr-queue queue-limit'. The remain percentage from your configuration will be implicitly applied to PQ. List if you use 'wrr-queue queue-limit 5 25 40', this will leave 30% queue size to PQ. My own question is that is this sufficient to limit the PQ bandwidth?
