CSS - Policy routing
Apr 21st, 2008
I have a requirement for the servers behind my CSS to access the internet. Currently I have ecmp enabled with two default routes specified. Is there anyway I can specify that when the servers initiate traffic out to the internet, that they only use a single specified default route vs load sharing across the two default routes currently defined?
Gilles Dufour Mon, 04/21/2008 - 23:04
  • Cisco Employee,
you can create a service with your prefered default gateway ip address and then use an acl to catch the server initiated connection and use the option 'prefer ' to force the traffic to go in that direction.
Make sure to configure the service as transparent to avoid nating the destination ip address.
Gilles
ccanning Wed, 04/23/2008 - 11:26
Gille,
Just to clarify, that I understood correctly. I also need to created a source group so that all servers appear as a single ip (see config below)
service server1
ip add 172.16.1.10
service server2
ip add 172.16.1.11
group all-servers
vip address 10.0.0.100
add service server1
add service server2
active
service def-gwy-server
ip address 10.0.0.1
type transparent-cache
acl 2
clause 10 permit any any destination any source-group all-servers prefer def-gwy-server
clause 15 permit any any destination any
Gilles Dufour Thu, 04/24/2008 - 03:51
  • Cisco Employee,
correct.
Except that if you define the service under the group, you do not need to use the source-group option in the acl.
Gilles.
