Passing 642-432 recertify CCNA?
Answered Question
Apr 21st, 2008
I have a vlaid CCNA and passed CVOICE(642-432) last week. Will this renew my CCNA?
If so, what is the new life of my CCNA?
Correct Answer by rob.huffman about 8 years 9 months ago
Hi SmallRain,
Yes, you should be good to go for 3 more years :)
CCNA Recertificaton
CCNA certifications are valid for three years. To recertify, either pass the current CCNA exam, or pass the ICND2 exam, or pass any 642 professional level or Cisco Specialist exam (excluding Sales Specialist exams), or pass a current CCIE written exam.
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
rob.huffman Mon, 04/21/2008 - 15:42
Hi SmallRain,
CCNA Recertificaton
Hope this helps!
Rob
rob.huffman Tue, 04/22/2008 - 05:24
Hi SmallRain,
You are most welcome! Best of luck in your studies, it sounds like you are on an excellent path.
Take care,
Rob
daledavis Thu, 04/24/2008 - 10:57
Very confused. This says to "recertify". But, MY CCNA is already expired! And today, I passed 642-552. Will my CCNA automatically be renewed?..even though its expired?
rob.huffman Thu, 04/24/2008 - 15:14
Hi Dale,
If your CCNA is marked as expired then sadly you must have missed the 3 year date from when you first passed. If that is the case then this will not recertify the CCNA.
Sorry my friend,
Rob
dgalati000 Wed, 04/30/2008 - 12:36
Smallrain- was that the V5 or V6 CVoice exam you took?
I'm preparing to try and get the old V5 in before the cutoff date of July 08.
What did you use to study with?
Was it a difficult cert test?
