Page all to IP Phones and E&M overhead speaker
Hello all.
I'm running CME 4.2 and am trying to setup a page all broadcast to both IP phones and an overhead speaker by dialing one dn.
I've tested both the IP phones and the speaker separately and can dial their specific dn's and get the paging feature to work but haven't had any luck getting both to work off of the same dn.
I've tried assigning them both the same extension but that doesn't work.
Running IOS 12.4(11)XW6. Thanks in advance.
bwilmoth Fri, 04/25/2008 - 11:42
  • Silver, 250 points or more
You need to assign two directory numbers since the router should know which one to broadcst to the amplifier
That is correct.
I opened a case with TAC and determined that there is not a way to put both paging systems on one DN (which was my initial desire.)
TAC relayed that this might be a feature in the 4.4 release of CME but that there were 3rd party applications available that would do it for us.
Client did not want to purchase any add'l software and is just using the 2 separate DN's.
