04-21-2008 05:27 PM - edited 03-03-2019 09:38 PM
Hi Experts,
I have one server, needs to be connected to 1Gbps speed to Core Switch.
On the Core Switch's port, it is a GigabitEthernet...so I have no problem with that.
my question is.. What is the different if I use Cat5e and Cat6 to plug in the server to the core switch??
Thanks!
Solved! Go to Solution.
04-21-2008 05:36 PM
Hey
I've used both cables before and I think both did the job when connected to 1Gbps ports.
But perhaps someone more experienced could add
Have you tested them already? have you plugged in both and noticed anything different between them?
04-21-2008 05:45 PM
Cindy, they'll both work just fine, but go with the Cat-6e if the distance exceeds 80 meters or so. Cat 6e is a higher grade cable and can handle Gigabit data rates at distances greater than cat 5e.
Victor
04-21-2008 05:36 PM
Hey
04-21-2008 05:45 PM
Victor
04-21-2008 05:58 PM
Thanks guys !
I will take note of this .. and rated the post..:)
04-21-2008 06:04 PM
You got it, Cindy.
Thanks for the rating.
Victor
