04-21-2008 06:00 PM - edited 03-05-2019 10:31 PM
I am failed to upgrade C3750E-24PD-S IOS to c3750e-universal-tar.122-40.SE.
Problem1:-
When i using tftpd32 to archive the tar file, from the tftp program log i can see 10054 error occur. i have using other tftp program but it shows same error code
also.
Problem2:
i am trying to delete update folder but i failed to do that.
I have attached the error with this two problem, please advise...
04-22-2008 12:27 PM
Code 10054 is related to timeout.
Before issuing tftp command on the switch, please make sure "exec-t 0 0" is configured under "line con 0) if connecting switch by console or under "line vty" if connection to switch by telnet.
For tftpd32, here is the best practises:
- Global Settings: TFTP Server / Client / Syslog server are selected
- Increase Tftp timeouts and Max Retransmit to 9.
- Make sure the tftp port is 69
- TFTP Security is Standard
- Advanced options will be default
04-22-2008 05:21 PM
Hello Wong,
Can you please paste the output of sh flash
Have checked the whether flash has enough space to accommodate the new image ?
How is your TFTP server connected to the switch ?
Padmanabhan
