UCM 6.1 and Syslog
Apr 21st, 2008
Is it possible to export the messages in the SysLog Viewer in RTMT to an external syslog server? I know I can configure alarms in the Serviceability webpage but I am looking to send all the System, Application and Security logs so its easier to sift through them.
smalkeric Fri, 04/25/2008 - 12:34
From the dropdown for both Local SysLogs and Remote Syslogs, could you check to see if the Alarm Event Level for " Emergency, Alert, Critical, Error, Warning, Notice and Informational " are enabled ? Also check the box " Apply to All Nodes " for the Alarm Event Level " configs for Emergency, Alert, Critical, Error, Warning, Notice, Informational, Debug alarm configs.
