Need dummy XML to post request to RME Remote Acess
Apr 21st, 2008
Could anybody provide me sample payload XML file to invoke cwcli from my machine.
I had gone through the user guide also but in that just following xml is given
<payload>
<command>
cwcli config export -u admin -p <Base64Enocedpwd> -device 1.1.1.1 -xml
</command>
<arg>
</arg>
<arg-val>
</arg-val>
</payload>
would this XML be enough to execute the command or I would need some header for above XML.
Overall Rating: 4.3 (4 ratings)
Joe Clarke Mon, 04/21/2008 - 22:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Actually, this payload file should be enough:
cwcli config export -u admin -p -device 1.1.1.1 -xml
er_yogendrasingh Tue, 04/22/2008 - 01:37
thnx for the reply,
can I execute cli like "sho ver" on end devices using these xml APIs
Joe Clarke Tue, 04/22/2008 - 09:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There's no way to do this in one step. You can run Netshow jobs from the CLI, but you cannot view their results in real time. First you will need to create the job:
cwcli netshow createjob -u admin -p -device 1.1.1.1 -customcmd "show ver"
This will return a job ID (e.g. 1007). Then, run a new command:
cwcli netshow jobresults -u admin -p -id 1007
er_yogendrasingh Wed, 04/23/2008 - 03:57
thnx a ton Clarke, for the reply.
that really helped a lot.
but I saw in the cwcli doc that user can only execute
. show
• version
• where
• ping
• traceroute
using customcmd option
what if I have to send some commands other than above.
in precise how can I send config level
commands using netshow(or some other application of RME) on to the devices
Joe Clarke Wed, 04/23/2008 - 08:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Netshow doesn't do config commands. For that, you want to look at the netconfig argument to cwcli. There is a lot you can do configuration-wise with Netconfig jobs. Check out the online help for RME for more details.
