MPLS over MPLS
Apr 21st, 2008
I wanted to run an MPLS cloud across to regional sites that are themselves connected via the service provider's MPLS. I don't want to merge MPLS domains, I want to run our cloud over the top (as you would with any other technology such as MPLS over frame or MPLS over ATM) i.e. MPLS over MPLS. I cannot find any references to this type of setup. Does anyone know if it is possible?
Andres
Overall Rating: 5 (1 ratings)
n.nandrekar Mon, 04/21/2008 - 21:20
  • Silver, 250 points or more
Hello Andres,
This would be possible using the mpls CsC ( Carrier supporting Carrier) architecture. Your mpls SP would act as the backbone carrier and you can run a mpls cloude through your regional locations.
the good book to reffer is :
Cisco - MPLS Configuration on Cisco IOS Software(2005)
Also,
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ftcsc8.html
Hope this helps.
Cheers,
Niranjan
joke Mon, 12/09/2013 - 12:03
Here is a link to a Cisco document that talks about running Enterprise MPLS over a carrriers MPLS network.
Use Case: Site-to-Site Communications Using MPLS L3VPN Services
This guide helps organizations deploy WAN services in order to connect remote locations over private cloud
Layer 3 VPN-based provider managed MPLS services.
http://www.cisco.com/en/US/docs/solutions/CVD/Aug2013/CVD-MPLSWANDesignGuide-AUG13.pdf
Cheers,
     Jim
