NetFlow on a Frame Relay - sub interface
Apr 21st, 2008
I have a frame relay sub interface which is doing frame-relay payload-compression packet-by-packet. Is it possible to configure netflow on this interface. Eventhough I configure on the main netflow entries pertaining to these interfaces are not available in the netflow cache. Please help
tstanik Fri, 04/25/2008 - 12:36
To configure NetFlow, first configure the router for IP routing Use the following commands beginning in global configuration mode:
interface type slot/port-adapter/port (Specify the interface, and enter interface configuration mode.)
ip route-cache flow (Enable NetFlow).
For the further configuration of the Frame Relay follow the link :
http://www.cisco.com/en/US/docs/ios/12_0/wan/configuration/guide/wcfrelay.html#wp5157
linker.team Sun, 04/27/2008 - 21:27
Thanks for your reply. Other frame relay interfaces which are not doing payload compression are available in the netflow cache entries. The only problematic interfaces are compression interfaces. Is it a limitation?
yjdabear Mon, 04/28/2008 - 06:24
Yes, unfortunately NetFlow does not support compression at this point.
