Boson's exam engine installation problem
Apr 21st, 2008
I need to install the Boson's exam engine which is provide with CCNA Official exam Certification Guide. I tried to install it but I didn't success. I met this problem "Error 1609. An error occured while applying security settings. Users is not a valid user or group. This could be a problem with the package ..."
I reinstall my Windows XP, but I still have the same problem.
Any idea !!! How can i resolve this problem !!! Thanks for your help.
francois.p Tue, 04/22/2008 - 01:37
I've opened a support ticket on the Boson support web site since 4th of April 2008, without any answers, any workarounds.
May be, this problem relate to my windows XP french version :o)
I'll try with a US/English version.
Thank you
jrensink78 Tue, 04/22/2008 - 06:28
I'm guessing that you already tried this, but try being logged in as the local administrator account and see if that helps. Sounds like a folder or registry permissions issue.
Also, check and make sure that you have a local group named Users. Maybe the French version has it named something else. If it's no there, create it, add yourself to it, and try again.
