igmp join group
Apr 21st, 2008
I have a WS-C3560G-48TS-S with IOS version 12.2(25)SEE.It will not take the command "igmp join group" when using multicast routing.Please tell me what may be the solution to enable multicast routing on that devices.the matter is very urgent.
ketimun123 Wed, 04/23/2008 - 03:20
In 12.2(25)SEE, all feature-set should support this command.
Do you want to use this command ?
ip igmp join-group 225.1.1.1
What error-message do you get ?
CSCO10685316 Wed, 04/23/2008 - 21:40
after interface config mode when I am giving ip igmp it is not showing join-group. After ip igmp i am getting three option
1)filter
2)max-group
3)snooping
Pls response
ketimun123 Thu, 04/24/2008 - 09:56
As of your listed config-options, I assume you try to configure a Layer 2 port.
If you change it to a Layer 3 port the command should work .
If you still have the issue, please attach sh ver and sh run.
