Application access thru Citrix Webconsole over Clientless SSL VPN
Apr 22nd, 2008
There seems to be few open issues accessing Citrix applications thru CitrixWebaccess over clientless SSL VPN on ASA 5540. The behavior differs for different versions of ICA client locally installed on the laptop / desktop.
The Auto-signon option for Citrix webaccess server and published citrix application seems to be working thru ICA client version 8.x alone.
With version 7.x and ver 9.x though application access seems to be working, however auto-signon doesn't work.
Auto-signon / Application access doesn't work for ICA client ver 10.100 / 10.200
Is there any known issues with accessing citrix applications thru SSL VPN OR with Cisco Adaptive Security Appliance Software Version 8.0(2)?
Appreciate any pointers to resolve this issue.
owillins Mon, 04/28/2008 - 06:22
  • Silver, 250 points or more
Try to install latest rdp plugin it will work . And also install citrix plugin will also support the same feature.
satishcp Tue, 05/06/2008 - 02:54
I had Citrix plugin installed. However with rdp plugin it doesn't seem to be working.
Any documentation from Cisco on how to configure Citrix meta / presentation server for SSL VPN?
