RPS2300 Sys Pwr showing - Bad
Apr 22nd, 2008
Hi all
We have just hooked up a RPS2300 to 2 Cat 3750 and diplaying
sh env power results in
Sw 1 - Sys Pwr - Bad
Sw 2 - Sys Pwr - Bad
Please can you help?
tstanik Mon, 04/28/2008 - 06:24
  • Bronze, 100 points or more
here are some details regarding RPS 2300 for review.
The Cisco Redundant Power System (RPS) 2300 increases availability for converged data, voice, and video networks. The RPS 2300:
Delivers power supply redundancy and resiliency for a variety of power requirements, including Power over Ethernet (PoE).
Helps ensure uninterrupted operation and protection against device power supply failures by providing seamless failover for Cisco switches including the Cisco Catalyst 3750-E Series Switches and routers such as Cisco Integrated Services Routers.
* Uses modular power supplies and fan for flexibility
* Allows users to define and implement the failover policy
Is backward compatible with switches and routers previously supported by the Cisco Redundant Power System 675
Has six RPS connectors and can simultaneously back up as many as two switches or routers
Reference link which will help you for the more details :
http://www.cisco.com/en/US/products/ps7130/index.html
