Error while web access to FWSM
Apr 22nd, 2008
Need help to run GUI for FWM.
I am trying to access the FWM module through https but it respond with the following error message:
“Cisco PDM 4.1 for FWSM encountered loading errors. If PDM has informed you about a problem in your setup, please fix the problem and try again” see attached for the graphical display.
1. My FWSM is:
FWSM Firewall Version 2.3(3)2
FWSM Device Manager Version 4.1(1)
FWSM-01 up 2 years 125 days
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash 2.20 TOSHIBA THNCF128MBA @ 0xc321, 20MB
2. my System running with JRE version 1.6.0_03 Java HotSpot(TM) Client VM
thanks
ezsurf0902 Tue, 04/22/2008 - 18:38
Hi Guys, any help?
wonder whether it got to do with the java version?
which Java version support the PDM 4.1? My current Java version is JRE version 1.6.0_03 Java HotSpot(TM) Client VM
thanks
jon.humphries Thu, 04/24/2008 - 10:26
Hi there,
I have had a similar issue it was a while ago. Rollback to 1.4.02 or 1.5.0.1 Java.
Hope this helps.
Jon
