Routing help on ASA 5520
whiteford
I have used the Site-to-Site VPN wizard on the Cisco ASA's ASDM and added a remote office, however I'm wondering what routes I need to add to the ASA so my internel network kow how to get to this remote network to bring the tunnel up? I thought the wizard would do this.
bwindle
Is your ASA the default gateway for your LAN? If so, then you should be OK. If not, then you'll need to add a static route on your LAN's default gateway to point the new subnet to the ASA (assuming you aren't using a IGP [RIP, OSPF, EIGRP, etc])
