Warning message
Jaime Valencia Tue, 04/22/2008 - 07:49
  • Cisco Employee,
  • Hall of Fame,
    2011
provide more info as that is not enough to advice, please also do so in the future posts
CUCM or CME? version
Unity / CUE / CUC? version
If unity Exchange? Domino?
javalenc
mohammed.guertit Tue, 04/22/2008 - 10:48
Its, CUC version 4.1 and CU, but I haven't the version of the CU, they are 2 separate appliances : CUC appliance and CU appliance
Crdl.
Jaime Valencia Tue, 04/22/2008 - 11:05
  • Cisco Employee,
  • Hall of Fame,
    2011
there is no CUC 4.1
try a MWI resync to see if that helps and verify the integration was done properly
javalenc
if this helps, please rate
mohammed.guertit Tue, 04/22/2008 - 12:49
I will try to have exact version
How can I try MWI resyn and check the propre integration?
Best regards.
Jaime Valencia Tue, 04/22/2008 - 18:24
  • Cisco Employee,
  • Hall of Fame,
    2011
as you have no idea of the version you have, you can check the documentation for all versions here:
Cisco Unity Connection
http://www.cisco.com/en/US/products/ps6509/tsd_products_support_series_home.html
If it's a CUCM BE there is another documentation on that, so please find out what you have
javalenc
mohammed.guertit Thu, 04/24/2008 - 10:45
Sorry the versions are :
Cisco unified Call manager 4.2
- Cisco Unity 1.2 (1)
Thanks.
Kenneth Mohammed Thu, 04/24/2008 - 12:50
  • Silver, 250 points or more
From Unity Connection Admin page, click on Tools--->Task Management---->then on the first page of tasks toward the bottom, you will see "Resynchronize MWIs on all phone systems"...click on that, then you go to "edit" and you can schedule when you would like to resynch the mwi.
Hope that helped
