Concentrator VRRP Configuration
Apr 22nd, 2008
I need help in configuring the VRRP on vpn concentrator. First I wana tell you how i configure my concentrator.
I enable VRRP, group ID and share addresses which is configured on master (my concentrator 1)
Then i copy its configuration and after modifying the public and private IP addresses I load it on my 2nd concentrator,
After upload, my 2nd concentrator is only able to access I am not able to access my 1st concentrator.
Shall I modify the configuration on 2nd concentrator for VRRP as backup or it is normal behaviour, I am using static routes and all rotues are point towards the IP of concentrator 1.
Tunnel will be made on Concentrator 1 Public Ip addresses.
If I reboot my 2nd concentrator during the time it comes back i am able to access the concentrator 1 as soon as it comes it, it is again not accessible.
how the configuration replicate, if i configure tunnel on concentrator 2, how to upload on concentrator 1. bcz I am not able to access it.
Shall i change configuration on concentrator 2 as backup VRRP Role.
Please guide
bwilmoth Mon, 04/28/2008 - 08:06
VRRP applies only to configurations where two or more VPN Concentrators operate in parallel. All participating VPN Concentrators have identical user, group, and LAN-to-LAN settings. You can refer this documetn for more information on configuring VRRP:
http://www.cisco.com/warp/public/471/vrrp.html
