ACS authorization for copy SCP
Apr 22nd, 2008
I configured the router to authorize all copy commands. Under ACS I need to allow only copy run: start: and Copy run scp: When I added under urguments:
permit run: startup:
permit run: scp:
it works fine for first one but for scp it will not.
When i checked the ACS under faild attempts. I found the ACS will not see any scp arguments. so to allow scp I should add:
permit running <cr>
which will allow all copies from running to any destination (for exapmly tftp. Can any one advice how I can restrict the copy commands for :
run startup
run scp
thanks
aghaznavi Mon, 04/28/2008 - 08:22
  • Silver, 250 points or more
may be you have a error in few commands in the Shell command authorization set. Verify the complete & correct syntax of the command from the device and then configure it in ACS.
