G729 prompt format
Apr 22nd, 2008
I have the format for G711 prompts but I am having trouble finding the parameters for the G729 file format.
Im sure someone knows what the file format is for G729, please let me know what the properties/parameters should be set to.
Thank you
adignan Tue, 04/22/2008 - 12:12
The format for G.729 is 8 bit ulaw. What are you trying to do?
G.729 is a proprietary, licensed, compression codec that must be purchased. You can't use Windows Sound Recorder to change a prompt from G.729 to G.711.
please rate helpful posts.
Abdulbaseer Mohammed Thu, 04/24/2008 - 23:01
As Andy pointed out you cannot change that . you use the same file format for your prompts.. ccit ulaw 8bit mono that is any recorder will do.
good luck,
sindhuravi Sun, 05/04/2008 - 23:02
Copy and drop the G.711 prompts in the below path of CCM server "C:\ProgramFiles\Cisco\MOH\DropMOHAudioSourceFilesHere". The G.711 prompts will be automatically converted to G.729 codec and migrates to CCM server to “C:\ProgramFiles\Cisco\TFTP PATH\MOH Folder”.
