US Robotic 5686e config for remote access
Apr 22nd, 2008
I am trying to input this string from ciscos website. at&f0qle0s0=1&b0&n6&u6&m4&k0&w though everytime I input it in my hyperterminal I keep getting errors. Please advise on what I can do to fix this or if I am doing something wrong. I have changed wires, tried on other laptops at work and tried other modems and still get the same error.
acomiskey Tue, 04/22/2008 - 08:02
What is the error?
What are your dip switches set to?
If you just do "at" and does it come back with "OK"?
vipaloce76 Tue, 04/22/2008 - 08:18
when I type in the string and hit enter the next line says ERROR
I have dip switch settings 1, 3, 8,
When I do AT it does come back with an ok
vipaloce76 Tue, 04/22/2008 - 10:33
Thanks for the help but I found that the modme defaults to com 1 and I didnt have it set to that once I did do that I was able to type in the string. I was being pointed to my internal modem thats why I couldnt type the string.
