How much does CallManager comply with AAA?
Apr 22nd, 2008
We wonder if CallManager complies with AAA or not? Such as before a user make a call, CallManager check with a RADIUS server first, and get authorization for a certain call, such as Long Distance toll call?
cris_jimenez Tue, 04/22/2008 - 10:50
CCM does not integrate with AAA. there are some other features that you can use to accomplish your task.
you would like to take a look to Forced Authorization Codes or Client Matter Codes. what this will do, whenever the user tries to place a LD, Intl call, the CCM will ask the user to type a code, if the user doesn't know the code, the CCM will reply with reorder tone, otherwise will route the call
let me know if that helps
