871 Router in SOHO setup using site to site VPN
Apr 22nd, 2008
I am setting up an 871 Router to use in a home office environment. It will typically be plugged in behind a Linksys router that will terminate the user's Internet connection. The WAN interface on the 871 will have to use DHCP. Also, I need to have the wireless enabled for the user on the LAN side of the 871. Is there a good document showing this setup? The site to site VPNs that I have configured have always had a static IP on the remote WAN interface instead of DHCP. Thanks.
mark.blanchfield Tue, 04/22/2008 - 10:39
I researched this and it seems my only option is to configure DMVPN. Can anyone confirm this? Also, we terminate all of our site to site VPN's on a 2851 router that has other site to site VPNs without tunnel interfaces and EIGRP. If I enable EIGRP, will this affect the existing site to site VPNs that are static and not running EIGRP? Thanks.
