04-22-2008 07:23 AM - edited 07-03-2021 03:45 PM
Hi all,
we are using 3 AP Aironet 1131 (Version 12.4(10b)JA3) in a WDS. All are connected to a Switch Catalyst Express 500 to receive their Power. The Problem is they work for some time and the the AP reloads without further errormessage.
Speed and Duplex mode are fixed on Switch and AP-Side. Does anybody now this problem or can give me a hint?
Thanks in Advance
Alex
04-28-2008 10:41 AM
This can happen if power settings are configured incorrectly on the AP. Ensure that the correct parameters are configured. Here is a link which explains how to configure power on APs.
Also, try disabling CDP and check if you are seeing the issue again.
04-28-2008 11:55 AM
thanks for the hints, but i found the issue: The problem was a damaged network cable. After exchanging the cable, all is working properly.
