No Outgoing Calls Allowed
Apr 22nd, 2008
Following the instructions for the initial setup of a UC520 with ISDN-PRI with 12 PSTN trunks, and only incoming calls on the PRI works. Our current analog number does not ring in on the UC520, and our telephone provider advised that its ported as our pilot number.
Question is: where do I go from here?
Does having no Data WLAN setup affect this? (Our server assigns the data ip addresses)
Should I set it up as a Key System Configuration instead of a PBX?
