7600 QoS
Apr 22nd, 2008
A SP has two 7600-Sup720 on the distribution layer operating as a L3 device (all the ports are configured as no switchports), they are using the 6724-GE linecard (simple LAN card). Now I need to apply QoS on those LAN ports.
My question is: Can I use LLQ or CBWFQ on those ports? or what type of QoS do I need to use (PFC QoS)?
Thanks for your answer.
aretsu Wed, 04/23/2008 - 12:31
Thanks Jon,
As far as i have read i cannot use the priority or bandwidht commands on a LAN card, so according with the document I need to user wrr-queue to configure queueing, is this right?
For (re)marking of packets I can use the internal maps (dscp to mpls and viceversa) or I can also use MQC for this, correct?
Jon Marshall Wed, 04/23/2008 - 22:47
Attached is the config from a 6724-SFP port in one of our 6500 switches
interface GigabitEthernet1/3
description *** Link to NW-MSQ1-F00-SW2 1/3 ***
no ip address
wrr-queue bandwidth 50 20 26
priority-queue queue-limit 4
wrr-queue threshold 1 40 100 2 40 100 3 40 100
wrr-queue cos-map 1 2 3 4
wrr-queue cos-map 2 2 1 2
wrr-queue cos-map 3 1 0
wrr-queue cos-map 3 2 6 7
mls qos trust dscp
channel-group 2 mode desirable
We have used the internal cos-to-dscp and dscp-to-cos to re(mark) packets.
aretsu Thu, 04/24/2008 - 06:33
Jon, thanks for your answer!
Just one more question: is this configuration valid if I am using the 6724 ports as L3 ports (no switchport)? I think the configuration is the same, i just have to take into consideration the DSCP to MPLS EXP mapping, is this correct?
Thanks for all your help!
