Applying BGP conditional advt when receivng default only from ISPs
Apr 22nd, 2008
Hi All,
How can we apply BGP Conditional advt. incase the local routers receiving only default routes from the ISPs..? In my scenario, I want Local rtr1 to be the primary...
2 local WAN rts, ebgp peering with seperate ISPs. Receiving defaul rts only (0.0.0.0):
Local-RTR1#sh ip bgp
Network Next Hop Metric Weight Path
*> 0.0.0.0 217.15.96.4 0 0 20520 i
* 217.15.96.5 0 0 20520 i
*> 62.31.67.0/24 0.0.0.0 0 32768 i
*> 8.27.120.96/27 0.0.0.0 0 32768 i
rtr BGP config:
router bgp xxxx
network 62.31.67.0 mask 255.255.255.0
network 8.27.120.96 mask /27
neighbor 27.150.9.48 remote-as yyyy
Local-RTR2#sh ip bgp
*> 0.0.0.0 21.23.53.157 0 8426 i
*> 15.35.14.0/27 0.0.0.0 0 32768 i
rtr BGP config:
router bgp xxxx
network 15.35.14.0 mask 255.255.255.224
neighbor 23.25.53.17 remote-as zzzz
Please suggest...
Thank you
MS
Edison Ortiz Wed, 04/23/2008 - 14:23
  • Hall of Fame,
    Founding Member
MS,
We need more information about your topology.
You asked about RTR1 being primary while RTR2 secondary but we don't know how the connection is made to the rest of the network and the routing protocol that is used, in addition to BGP.
Per your output, there isn't enough information to make one router preferred over the other one as both are receiving a default route from different providers.
__
Edison.
