HW Limitation for 2800 Series Routers
Answered Question
Apr 22nd, 2008
How do you determine the HW limitation for 2800 Series routers ? I cannot seem to find any related docs for this.
Would a 2811 Router be able to handle upton 4.5Mbps of WAN traffic (Using 3 WICs) ?
Naman
Correct Answer by Richard Burts about 9 years 3 months ago
Naman
This link gives approximate performance levels for the routers in the 2800 family:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
According to table 1 the 2811 will handle 2 T1s. To handle 3 T1s it looks like you would want a 2821.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 04/22/2008 - 10:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Naman
Rick
Richard Burts Tue, 04/22/2008 - 11:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Naman
I am glad that the information that I found was able to resolve your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read responses which were able to resolve the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Joseph W. Doherty Tue, 04/22/2008 - 13:59
Another method for estimating performance is reviewing the "Router Perf" document often referenced in these forums (attached). In this document, you'll note the 2811 maxs out at about 61 Mbps. This would seem to imply a 2811 might be able to handle more than dual T1s.
Actually, I work with a client that use 2811s at many remote sites with up to 4 T-1 (both MLP and IMA); seems to handle such, without problems.
