Ideal test rack for CCNA and CCNP prep.
Apr 22nd, 2008
I want to build Rack for my upcoming CCNA exam. I do have 6509 with SUP 1a+ MSFC card. Also, I have two switches.
1) 6509
2) Cat2948L3
3) Cat3550
Can some one tell me what else hardware do i need to build ideal CCNA lab rack.
Thanks.
aggie1234 Tue, 04/22/2008 - 15:27
Thanks a lot for your time. I do have 6509 which allow me to configure any setup. I just wanted to know what else i have to add in rack. I do have toask friend of mine for other gears. I know he will has it but i need to know what to ask for...
Thx.
jtryan1 Mon, 04/28/2008 - 10:51
1 Router with 4 serial ports. Use this for your frame-relay switch.
3-4 routers with at least one serial port and one Ethernet port. You can use 2501 routers.
4 - DTE/DCE serial cables.
With this setup you can work on any technology frame-relay, routing, (RIP, OSPF, EIGRP, BGP).
If you get routers with more serial and Ethernet ports you can do back-to-back serial for PPP, standby links, etc.
jim_berlow Mon, 04/28/2008 - 11:12
That 6509 is probably overkill for the CCNA (and is probably running CatOS which isn't relevant to the CCNA). Looking at your setup, you will need to add several routers (at least 4 for the CCNA and probably 6-8 for the CCNP). For those routers, I would look at 2620's outfitted with WIC-1Ts. The 2620's have an advantage over the 2610 and 2501's (as someone else recommended) as the 2620's have Fast Ethernet interfaces.
Your other two switches should work fine. I might also suggest that you get a terminal server (2511 w/ octal cables) and a frame switch with at least 4 serial (maybe you use your 6509 for this?)
Good Luck!
aggie1234 Mon, 04/28/2008 - 12:34
Thanks for update.. I do have 6509 that running catos but i am planning to upgrade it to IOS because I have MSFC card in SUP mod. I do have termserver from different company. I have racked up some equipments and getting some more...
