Possible use Cisco VPN client to connect to 877 router?
Apr 22nd, 2008
I have a Cisco 877 at home and I was just wondering if it's possible for me to use my cisco VPN client on my laptop to connect to my 877?
I use it to connect to my works ASA and Concentrator, but it would be useful for me to access my home network remotely.
JORGE RODRIGUEZ Tue, 04/22/2008 - 13:58
According to DATA sheets you can configure the device for VPN remote access.
870 series data sheet
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976_ps380_Products_Data_Sheet.html
Configuring VPN Remote access - 850 & 870 series
http://cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/vpngre.html
Rgds
Jorge
rate any helpful post if it helps
whiteford Wed, 04/23/2008 - 09:28
Thanks, isn't this pointing more towards having a a site-to-site VPN between to 800 servies routers?
I just would like to connect to my home 877 using my Cisco VPN Client from anywhere.
