Updating Telnet Credentials
Answered Question
Apr 22nd, 2008
I am running LMS 2.6 and since we can't set a default for the telnet credentials, I'd like to know if there is a way to run a job that sets these passwords on all devices at the same time? All devices have different community strings so I don't want those to all be the same. Is there a way to just change the Telnet Passwords all at the same time? thanks, marcie
Correct Answer by Joe Clarke about 9 years 1 month ago
Do NOT touch any field you do not want to change. Just change the fields that should apply to all devices.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 04/22/2008 - 10:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Sure. Just go to Common Services > Device and Credentials > Device Management, select all your devices, then click on Edit Credentials. Only fill in the telnet credentials, then click Finish.
sirbaughmf Tue, 04/22/2008 - 11:15
Ok, but I just want to make sure of one thing...when I do that and bring up Standard Credentials page there appears to be entries for the community strings (dots)....should I delete these? Will that remove them from the DB when I apply?
Correct Answer
Joe Clarke Tue, 04/22/2008 - 11:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
