04-22-2008 10:51 AM - edited 03-13-2019 05:11 PM
I currently have a DHCP server configured on UCM. I want to move this to the switch that the UCM and all my phones are connected to. Do I need to delete the DHCP server from the UCM as I configure DHCP on the switch due to broadcast? Is there just a way to disable it, or do I have to delete it?
Solved! Go to Solution.
04-23-2008 03:50 AM
Yes, you have got it right. You are currently running DHCP on the CallManager. Disabling this service will disable DHCP on the CallManager and you would be able to use another DHCP server [switch in your case] for the IP Phones.
->Sushil
04-23-2008 01:26 AM
You can disable the DHCP Monitor Service from serviceability window of Cisco Unified Communications Manager.
Once this is done delete the DHCP server. System > DHCP > DHCP Server
-> Sushil
04-23-2008 01:54 AM
That's right
04-23-2008 03:40 AM
Just to clarify, disabling the DHCP Monitor Service will still allow me to hand out DHCP from another source (switch)? DHCP Monitor Service is only used if you are using UCM as the DHCP server?
04-23-2008 03:50 AM
->Sushil
04-23-2008 03:55 AM
Thank you very much Sushil.
04-23-2008 03:57 AM
No problem man!
05-13-2008 06:26 AM
I was able to remove dhcp server from CUCM and then enable on switch, however, the Linux Kernel didn't recognize that I killed the dhcp server, so it was still handing out addresses. We couldn't figure out how this was happening because there was no dhcp server on the CUCM anymore. TAC dialed in and SSHed to my Publisher. He found that the dhcpd service was still running even though we had killed it. Odd! Anyhow, after he stopped it, all was good.
