Does Cisco 10000PRE2 support EtherChannel?
Apr 22nd, 2008
Greetings.
We have a Cisco 10000PRE2 router running in ISG mode with the following config:
Cisco IOS Software, 10000 Software (C10K2-P11-M), Version 12.2(31)SB11, RELEASE SOFTWARE (fc3)
NAME: "Chassis", DESCR: "C10000 Edge Service Router (ESR) Chassis"
PID: ESR10008-CHASSIS , VID: V02 , SN: FOX10461842
NAME: "module 1/0", DESCR: "1 port Gigabit Ethernet Half-Slot Line Card"
PID: ESR-HH-1GE , VID: V01 , SN: CAT1039530R
NAME: "module 2/0", DESCR: "1 pt Gigabit Ethernet line card (requires a GBIC)"
PID: ESR-1GE , VID: , SN: CAT10465NRH
NAME: "module 3/0", DESCR: "1 pt Gigabit Ethernet line card (requires a GBIC)"
PID: ESR-1GE , VID: , SN: CAT10465NM8
NAME: "RP A", DESCR: "Performance Routing Engine"
PID: ESR-PRE2 , VID: V02 , SN: CAT10455FYE
NAME: "RP A flash card 0", DESCR: "Flash Card"
PID: ESR-PRE-MEM-FD128 , VID: , SN:
NAME: "power-supply 0", DESCR: "AC power entry module for ESR10008"
PID: ESR-PWR-AC , VID: , SN:
NAME: "fan-tray", DESCR: "BLOWER ASSEMBLY FOR ESR10008"
PID: ESR-BLOWER , VID: , SN:
No matter how i tried, i could not get two or three of these network cards working int GigabitEtherChannel mode, however, this link: http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/sbcelacp.html says it's possible. Ports (including Port-Channel interface itself) go up, but no frames are passing through. Had anyone success with this matter?
Or, does anyone know, if 10G module is planned for this chassis? I have nearly 900M of traffic passing through it, and desperately need some reserve.
Thanks a lot!
amritpatek Mon, 04/28/2008 - 10:58
  • Silver, 250 points or more
The 802.1q support on GEC for c10k (PRE-2 and PRE-3) will be available in 12.2SB release-5. We are currently working on getting the 802.1q support on GEC into the release-4 throttle branch. It should be available in future rebuilds out of the 12.2(31) SB.
unicorn.odessa.tv Mon, 04/28/2008 - 15:45
Thanks a lot for your answer!
I'm not quite sure i understand though: 12.2SB release 5 is older that 12.2SB31, or not? And how about 12.2(33).SB, that became available recently? Will 'ip subscriber routed' will be supported on 802.1q-based vlans on GEC?
Thanks again.
