FXS Port in 2801
Apr 22nd, 2008
We have a VIC-4FXS card in a 2801 with a analog phone hooked up to port 0 currently. We are going to hook up a fax machine that ties into CCM 6.01 BE. Whenever we pick up the phone it gets no dialtone and when I dial out it doesn't do anything. If I dial the extension associated with the phone it gets busy signal.
The gateway configuration shows the VIC-4FXS card in it. Port 0/0/0 shows POTS which is the appropriate pool and CSS As the other phones and incoming lines.
Port Direction - Both Ways
Prefix DN - Nothing
Num Digits - 13
Expected Digits - 0
SMDI Port Number - 0
Any ideas or help on troubleshooting this?
paolo bevilacqua Tue, 04/22/2008 - 12:10
  • Hall of Fame,
    Founding Member
Check the line using a phone, if you get busy when calling from outside, either a call got stuck on the 2801, or you have an issue with the line.
Steellllllllll0 Wed, 04/23/2008 - 06:14
Have you checked you have enough dsp resources to support the voice card with a sh invent.also, are u using an mgcp/h323 gateway ?
