AXL - addCSS Example
risiprekel
Does anyone have a working addCSS example? I've built out the command and I get an OK response, but nothing ends up in the database... I think its something to do with members, so I would like to see someones working example and compare it to mine... Thanks! (Or anything with members, just not phones).
Sascha Monteiro
Level 6
Level 6
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> http://www.cisco.com/AXL/API/1.0" sequence="1">CSS_TST_PSTNTEST PSTNP_InternalP_TST_PSTNP_VMPILOT_N
6 Replies 6
Sascha Monteiro
Level 6
Level 6
Here is the post I am making. I get a 200 response ok. No soap/axl errors. Nothing ends up the the database... Where am I going wrong?
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" xmlns:xsd="http://www.w3.org/1999/XMLSchema"> http://www.cisco.com/AXL/1.0" xsi:schemaLocation="http://www.cisco.com/AXL/1.0 http://192.168.200.90/schema/axlsoap.xsd" sequence="1234"> WieeTESTbryce-PSTN-911-PTDenis-PSTN-911-PTDenis-IPPhones-PTDenis-PSTN-LD-PTDenis-PSTN-911-PTDenis-IPPhones-PTDenis-PSTN-LD-PTbryce-PSTN-LD-PTDenis-IPPhones-PTDenis-PSTN-911-PTbryce-IPPhones-PTbryce-IPPhones-PTDenis-PSTN-LD-PTDenis-IPPhones-PTDenis-PSTN-911-PTbryce-IPPhones-PTDenis-PSTN-LD-PT
This is against a CM 4.2
I found the error. You'll notice a tag is built incorrectly in the sample. My string was built wrong in a cycle. Corrected. It works. Thanks for the help.
I am glad it works, please rate my post if it was helpful
cheers
Sascha
Will do!
Have any addRouteGroup Examples?
