AAA Accounting of http
Apr 22nd, 2008
We are going to implement AAA with ACS. Now I'm testing AAA on Aironet APs. AAA is working fine, the ACS is able to authenticate/autho/accounting for me, and records all the commands entered on AP...this is fine..
But when I login and do some changes thru web the accounting is not working, even if I change any values its not recording these values into the ACS accounting.
Does anyone implemented aaa for http also, please let me know..
andrew.butterworth Wed, 04/23/2008 - 05:32
I assume you have added the command:
ip http accounting commands 15 default
Either default or the accounting list name you created? If this doesn't work then I suggest you debug and see if the router is sending the accounting packets.
