route leaking in sngle command
Apr 22nd, 2008
we are having a vpn red having rd x:y this is spread over 600 locations; now i am leaking a route of my internet vrf and want to import this route to vpn red. problem is that everywhere i have to add the import command means add it to 600 PE. It's a cumbersome work. Do we have any solution for this thru which in a single step all can see the same leak route.
Overall Rating: 3.5 (2 ratings)
Harold Ritter Wed, 04/23/2008 - 22:32
One solution would be to selectively add the vpn red route-target extended community to this specific route in the vrf internet using an export-map. This way you would have only one router to touch. It would go something like this.
ip vrf internet
export map test
route-target export
route-target import
route-map test permit 10
match ip address 10
set extcommunity rt additive
access-list 10 permit
Refer to the following document for more information on export-maps.
